Remove Expo Dry Erase marker from car
My son decided my car would be much cooler if it was a police car, and used an expo marker to draw on the car. The 2x4 on the roof was an extra touch to look like a police light bar.
I've tried my favorite ink removers: acetone, rubbing alcohol, gasoline, and full strength bleach. In some cases the ink came out 100%, but mostly the faint lines are still visible.
Anyone have a removal trick for me?!
Thanks!
Thanks!
I would think those solvents would be stronger but there is dry erase board cleaner. If nothing else, I would think it would be harmless to the paint so you could let it sit a few minutes before wiping.
After that, I'm into polishing compound....
Try something with ammonia...pretty sure that's what's in the dry erase board cleaners. And a maintenance guy at the place I used to work said he used barkeepers friend as a last resort to rejuvenate white boards that were badly stained. But I would test that in an inconspicuous area first.
Dry erase markers are water based.
I've used a mixture of rubbing alcohol and lighter fluid to remove it.
Have you tried WD-40. It removes ink marks pretty good and won't affect the paint. Of course pictures will help, and will give a certain entertainment value to us
