Bathroom sink rust stain
Received 0 Votes
Looking for some ideas or tips to remove the rust ring around my bathroom sink drain, see image. Thanks.
Paul
Paul
There is no way to remove the rust ring. That's the sink actually rusting.
You can pull the strainer out, sand the metal and then carefully paint with a good oil based or paint meant for porcelain applications.
I doubt vinegar will help with a rusting cast iron sink. Normally rust doesn't occur on the stainless or chromium of the drain, so the advice given so far will be about all that can be done.
