Cleaning toilet
Old 05-25-17, 06:11 PM
Cleaning toilet
how do you plug up the hole in a toilet so you can fill the whole bowl up to the top with cleaner,vinegar...??
Old 05-25-17, 06:16 PM
Received 85 Votes on 80 Posts
Why would you?
Any clinging toilet bowl clean like this squirted under the rim will clean and sanitize the whole bowl in seconds.
Old 05-25-17, 08:47 PM
Gunguy45's Avatar
Super Moderator
Received 4 Votes on 4 Posts
Whatever fits and is too big to get sucked in accidentally. Tennis ball or kids rubber ball come to mind.
Old 05-25-17, 08:52 PM
Received 1,404 Votes on 1,299 Posts
I use a Lysol product that really works well. The link is below. Since it comes with a pour spout.... I pour it down the overflow tube inside the tank. It runs down the rim inside the bowl and cleans from the top down.
LysolŪ Power Toilet Bowl Cleaner with Lime & Rust Remover
Old 05-26-17, 12:53 AM
Gunguy45's Avatar
Super Moderator
Somehow I'm guessing that the issue might be plugged or smelly holes under the rim. If they are plugged, a bent coat hanger and an inspection mirror will be needed. If they are smelly, bleach poured in the overflow multiple times should correct that. If not, you probably need to replace the toilet.
