restoring Cultured Marble
Old 08-09-17, 09:54 PM
R
I have a Cultured Marble shower which has a brass frame around the glass door and window. I want to change to a frameless shower frame but the old brass frame left the Cultured Marble yellowed where it was attached to it. Is there a way to clean the yellow stain from the Cultured Marble
Old 08-10-17, 06:55 AM
Limestone Cleaner | Marble Cleaner | Sure Klean
That company has some good products.
Old 08-10-17, 10:14 AM
Handyone's Avatar
Welcome!
Depending on how far you want to take this, the surface can be renewed.
Here's a link to a product called Gel-Gloss:
https://www.lowes.com/pd/Gel-Gloss-1...eaner/50305771
The Gel-Gloss alone might be enough to clean the stains. If not the surface can be wet-sanded and buffed similar to a car.
I consider the buffing advanced. You would need a buffer and automotive finishing compound, then reapply the gel coat.
Old 08-10-17, 11:52 AM
czizzi's Avatar
Received 14 Votes on 12 Posts
I've buffed out minor scratches to the surface of older cultured marble with a car polishing compound. However, if yours has discolored, it may be difficult to restore depending on how deep the discoloration goes.
Old 08-10-17, 04:44 PM
Buffing with polishing compound sounds like a great first choice. Go for it.
