Pressure Washing mildew UNDER YOUR HOUSE
Old 02-20-18, 01:55 PM
F
i have some water issues that I HAVE found out where water was coming in.. Iam fixing that problem.
What I see is mildew that has come under the house.. It is a dark blue no white..
How to remove this? Can i pressure wash it off.. Like spray on a mildew remover and then wash it all off?>??
This is on one end of my house, I have a 8gpm hot washer
Old 02-20-18, 03:00 PM
Received 786 Upvotes on 689 Posts
Pics would give us a better idea of what you have going on.
I normally spray a bleach/water solution on the mildew and the rinse with a pressure washer.
Old 02-21-18, 08:55 AM
F
how long let is set before you wash it off??
Old 02-21-18, 08:59 AM
I let it set but not dry, then rinse.
Old 02-21-18, 02:33 PM
F
I was told to spray on Sodium hydroxide or sodium hypocrite 50/50 then revise off
What you think about either??..
Tks for your thoughts on this matter..
Old 03-05-18, 07:23 PM
F
How about RMR 86 will that do it???
Old 03-06-18, 03:24 AM
It should work although I don't have any experience with that product. I almost always use bleach because it's cheap and effective.
Old 03-06-18, 11:26 AM
F
Im going to mix in a gallon of bleach with it
Old 03-19-18, 10:45 AM
airman.1994's Avatar
Received 8 Upvotes on 8 Posts
What is the mold on? Im not sure spraying more water under a house that already has mold is the best idea.
Old 03-19-18, 11:07 AM
F
Its all on plywood and joist.. It is 3' tall craw space..
putting it on with a 2 gallon sprayer,,
Old 03-20-18, 10:16 AM
Id get a chemical that is designed for killing mold. Bleach kills mold but has no kill time past 24 hours. Most chemicals designed for killing mold can kill up to 6 months. once the bleach is gone from your mixture you are left with the water. water is what caused your issue the first time. I would not fix the mold issue until you have fixed the water issue.
Old 03-20-18, 10:40 AM
Y
Received 24 Upvotes on 23 Posts
I have not yet tried "Wet and Forget" but there is some here for mold/mildew on our concrete patio...a lot of which is in the shade.
It is 10% Alkyl Dimethyl Benzyl Ammonium Chloride. Spray on and do not rinse or touch again. Takes awhile to work.
