Clean, recaulk bath surround
Old 01-30-19, 10:03 PM
C
I've had some mold in a few areas around the bathtub for months.
I tried industrial cleaner, vinegar, baking soda, alcohol, pumice stone, Magic Eraser and
then finally Clorox Clean Up w bleach. The next day, there wasn't a trace of it.
Now I see some cracks in those areas. I was going to just put some caulk over them.
Then I see for some reason that's a no no - nobody ever says why! I did see a product that you can do
his...Permatex or something. Any experiences with this?
Old 01-30-19, 10:18 PM
Marq1's Avatar
Received 1,210 Upvotes on 1,098 Posts
Dont do that, bet it's silicon caulk?
Need to remove and use newer siliconized latex caulk with microban!
Old 01-30-19, 10:36 PM
C
It's Polyseamseal. Says: "Water based caulk provides a crack-proof seal...Watertight seal resists surface mold and mildew growth". Right :-(
Old 01-31-19, 04:57 AM
Received 800 Upvotes on 703 Posts
As noted above it's best to cut/pull out the failing caulk and recaulk. You can buy a little time by just caulking the voids but putting a new bead of caulk over the old seldom fares well.
Old 01-31-19, 05:16 AM
Marq1's Avatar
Try DOW products, have been using for years without issues!
Old 01-31-19, 05:57 AM
P
Received 2,010 Upvotes on 1,802 Posts
Yes, you need to remove the old caulk. New caulk will not stick well on top of the old and the old mold will be visible through the new caulk.
