aluminum garage door cleaner
Old 12-04-19, 09:54 PM
B
Which cleaning products are safe to use on aluminum garage doors ?
Old 12-05-19, 02:34 AM
Doorman2722's Avatar
Received 42 Upvotes on 41 Posts
There aren't a lot of aluminum doors out there, are you sure your door isn't metal? If so you can wash it like you would wash your car.
Old 12-05-19, 03:12 AM
Received 840 Upvotes on 737 Posts
Ya, the odds are your door is painted steel. What cleaner to use is somewhat dependent on what needs to be cleaned off of the door. You can use pretty much any household cleaner.
Old 12-05-19, 04:34 AM
Marq1's Avatar
Received 1,210 Upvotes on 1,098 Posts
Every few years I wash my house, and garage doors, Simple Green is great, cuts through the grime, doesn't hurt plants and smells nice!!
Capable_Wife voted this post useful.
Old 12-09-19, 12:05 PM
B
Directions seem to say - "2 tablespoons of Simple Green per gallon of water". Is this ration what you recommend ? Thanx.
Bob
Old 12-09-19, 12:30 PM
Marq1's Avatar
Most of the time it's sprayed directly onto the siding from some high efficient bottle sprayers then using a brush, or it's a 5 gallon pale with several "glugs" of cleaner, not much measurement going on!
Old 12-16-19, 10:30 AM
B
Hi Mark: you are correct - door is steel not aluminum. Apparently Simple Green is OK to use carefully. Do you agree ? Thanx.
Bob
Old 12-17-19, 02:18 AM
Yes, most any household cleaner will work fine.
