just cleaned black mold spot off basement drywall under sewage drain
not sure if some of the stuff that I moved out that was butted against the drywall cause the mold (which in that case is fine since the stuff is gone) or if there's a small leak in the sewage pipe (inside the wall) and there's mold on the other side.
if it's the latter, is the only way to check to bust open the wall to see what's on the other side or is there any type of device that can scan for black mold on the other side?
