aluminum "tarnish"?
aluminum "tarnish"?
Didn't know where to put thsi so I thought I'd throw out here.
When handling aluminum, such as bar stock or unpainted aluminum window frames, your hands get a dark, almost black film like coating on them. What is this called? It pretty much washes off. Might take two washings with soap.
Its oxidation. Just like copper tarnishes and steel rusts. Cameo aluminum and stainless cleaner is a good cleanser to use on aluminum pots and pans. White vinegar is also said to work well.
Norm201
voted this post useful.
Yea, but a bit more!
Rust, which only occurs with metals with iron, slowly disolves the base material, aluminum corrodes creating a layer of oxide that acts as a protective barrier.
That is why iron needs a protective coating (paint/plating) to survive where as aluminum is more of a cosmetic treatment!
Yet the aluminum looks as shiny as ever.
The aluminum's oxide layer is quite soft which is why it easily rubs off onto anything. Anodizing performs a similar job but is much harder so you don't get the black dirty marks when working with anodized aluminum.
