Ultrasonic solution to clean door hardware
Old 08-16-20, 09:54 AM
T
Received 2 Upvotes on 2 Posts
Doing front entry facelift. Was going to just replace 15 yr old tarnished (antique brass?) latch and deadbolt set but occurred to me that I might be able to clean it in my ultrasonic. Anyone know of a DIY solution that might work?
Thanks
Old 08-16-20, 12:57 PM
Marq1's Avatar
Received 1,210 Upvotes on 1,098 Posts
A 15 year old entry set has seen better days, must be all corroded and the finish peeling, I dont think any amount of cleaning is going to revive that!
joecaption voted this post useful.
Old 08-16-20, 01:21 PM
P
Received 2,114 Upvotes on 1,893 Posts
Most of the visible hardware I have seen is plated, cast zinc. Antique finished are often painted. I would start with solvent to see if you can dissolve the paint. Then you could paint on a new finish. If your handle is real cast brass then it's relatively easy to either polish or distress it to your liking.
Old 09-12-20, 09:47 AM
T
Could not clean it. Replaced it.
