Hardened stain on glass/ceramic stove top?
Old 11-18-20, 07:35 PM
Hi, was making some sweet soup and some drops of water might've spilled on the surface and now it became hardened and formed a web-like patch (tiny circle). I tried the typical cleaning procedure of wiping with detergent and that did nothing. How can I get this type of stain off a flat surface stove? It's a new stove that just came in 2/3 weeks ago. Also any suggestions on how to clean these stoves would be much appreciated!
Old 11-18-20, 07:45 PM
XSleeper's Avatar
Received 1,844 Upvotes on 1,659 Posts
Possibly looks like sugar crystals. I would first try boiling some water on the stove, and slowly drip some of the boiling water onto it, and see if it dissolves.
For general cleaning, you should generally use ceramic cooktop cleaners on it.
Old 11-18-20, 08:33 PM
Received 3,750 Upvotes on 3,362 Posts
A recent thread on a similar problem..... how-to-remove-white-cloudy-stain-on-glass-stovetop.
Old 11-19-20, 07:19 AM
H
Received 279 Upvotes on 239 Posts
Soaking overnight with some wet paper towels will dissolve sugar or starch AROUND the burner.
ON the burner, it gets caramelized into a glassy layer like the "seasoning" on an iron skillet.
https://www.facebook.com/hal.schirme...ssed&ref=notif
Old 11-20-20, 04:13 PM
I have tried with baking soda and vinegar, and just wiping against the stain but it didn't come off. Ill try with boiling water and soaking overnight as well as I might've rushed the wiping process and did not let it dissolve. Would the razors that come with cleaning kits on amazon work for these types of 'stuck on' stains? Thanks everyone for the responses!
Old 11-20-20, 04:18 PM
Marq1's Avatar
Received 1,210 Upvotes on 1,098 Posts
Its etched, nothing will take it off have tried for years to clean ours!
Old 12-05-20, 03:29 PM
Managed to get the stains off with a stove top cleaning kit razor (weimann's). The razor works wonders and scraped it off after applying a bit of pressure. Cheers
