What is this unsightly orange stain in the plastic shower pan and how do I get
rid of it?
Tried the goo gone spray and foaming and scrubbed the tar out of it but the orange stain is standing its ground.
Any other ideas short of bringing out the sander?
TIA
TIA
Foaming Kaboom. Sticks and works well. Has bleach and has fumes.
Spray the area, get out and let it sit for an hour. Come back in and rinse it off.
I get it in the supermarket. Walmart has it.
Foaming Kaboom
Foaming Kaboom
It is most likely either a type of mold or iron from the water.
Depending how worn the surface is the stain could be permanent.
If mold you could soak a rag with a strong bleach/water mix, lay wet rag on stain and keep it wet for a time.
If rust you could make a paste out of a powdered iron remover and water. Spread the paste on the stain and keep it wet.
Laying plastic food wrap on the paste would keep it wet longer.
Iron stain was my first thought also.
If it's an older pan, in that it's lost some of it's surface coat then the stain is probably into the substrate and going to be difficult to get out.
In tile showers an acid based grout cleaner works but in a fiberglass/acrylic tub it probably will do more damage!
