Cleaning bath tub
Old 12-18-20, 05:13 PM
W
Received 1 Vote on 1 Post
Cleaning bath tub
One of our bath room has not been used for one year. When we opened this bath room to take the bath, it was found that some black stain (maybe mildew?) inside the bath tube near drain hole as shown in attached picture. We have tried lots of cleaners such as bath tube cleaner, bleach and Blanqueador powder with bleach, but not lucky, although the black color went to light. Any suggestions?
Old 12-18-20, 08:53 PM
Received 2,952 Votes on 2,664 Posts
That looks like the pattern from the back of a shower mat.
What kind of tub is this..... porcelain or acrylic (plastic) ?
Old 12-19-20, 04:31 AM
P
Received 1,561 Votes on 1,404 Posts
Get a stiff bristled brush and clean some more. I can see where you cleaned away the dirt from the high spots but you've still got more cleaning to go. A mild abrasive scouring powder or jell might be good to try.
Old 12-19-20, 04:47 AM
Norm201's Avatar
Received 594 Votes on 531 Posts
If you used any type of scouring powder, you've made a permanent spot for dirt to reside. You must use a non-abrasive cleaner. Something such as Bon-Ami.
Old 12-19-20, 07:42 PM
W
the bath tub is made of plastic
Old 12-19-20, 07:55 PM
W
I have tried Ajax Powder Cleanser and Comet Cleanser w/Bleach, clean some but not all. The picture shows remain.
What type of jell is recommend? Such as ...
Thanks
Old 12-20-20, 05:14 AM
Norm201's Avatar
Too late. With those cleanser you made a permanent spot for dirt to gather (they are very abrasive). Especially with plastic. Possibly a coating of some sort might cover it. A very light sanding or grinding might remove it then using a clear water proof coating.
