Greetings All:
I used my extension pole with a brush attached to clean my exterior vinyl siding this past October. Water got down into the pole and I tried to get it out by leaving it upside down, but it still rusted. The last section will seized and it takes a lot of effort to get it working again. Tried WD-40, but it did not help. Is there something else I can put on the rusted part of the pole to keep it from seizing? Attached is a picture of the problem area.
Pretty hard to stop the rust from happening.
You'd need to use something that stayed in place.... like a light grease or maybe even Vaseline.
WD-40 would just be washed out by the water.
Are you saying its stuck and you can't get it fully extended? Or the problem is the rusty spot in the photo? If its just the one spot, just clean it up with a green scotch brite pad or steel wool until it shines. Then either spray paint it or keep it greased up.
But if it's siezed, you probably need to put a vise grips on each end (not in the middle where it will crush it) and have a friend help you work it back and forth, pulling it apart to extend it. Keep after it with wd-40 or pb blaster until you get it free. Once you can fully extend it, keep spraying and use the scotchbrite pad to clean any rust off that you expose.
Rust expands, so that's why its tight and won't move easily.
I'm thinking that I may have black mold behind the procelain tile in our walk in shower. The grout and silicone are still good (no visible cracks or leaks) and looks clean and white all over. However, I see this "shadow" on the bottom row of tiles, and a couple tiles have ring spots (see pictures).
[b]Note[/b] - the shadow and ring spots are "[u][b]inside[/b][/u]" the tile, and cannot be cleaned away with bleach or vineager no matter how many times I try.
What do you think? Should I destroy a clean looking shower due to this shadow? Is it normal for mold to darken tile from the inside like this?
[img]https://cimg8.ibsrv.net/gimg/www.doityourselft.com-vbulletin/2000x1031/shower_9fdd6967271733cd4f92a704c790092333953aa6.jpg[/img]
[img]https://cimg2.ibsrv.net/gimg/www.doityourselft.com-vbulletin/2000x1439/shower2_8ee9e308c41fcd365ca2e3545c20ceea197da139.jpg[/img]Read More
One of our dogs either threw up or had some diarrea on the carpet in our upstairs room several days ago. Didn't notice it till today. :(
I am looking for suggestions for the best DIY home mixes or even store bought cleaner that is most likely to help get rid of the stain. I am currently using this mix.
2 Cups of water
1 Tbsp of salt
1 Tbsp of dishsoap
1/2 Cup of Vinager
This is starting to get it but I was hoping that maybe someone has come across a "special mix" or weapon for these kinds of stains.
Thanks for your help.Read More
