What will clean really filthy white gutters?
Old 06-09-21, 08:06 PM
Received 2 Upvotes on 2 Posts
These gutters haven't been cleaned in fifty years. What might at least make them look a little more presentable? Some cleaning solution? A power washer? Any suggestions? Thanks.
Old 06-09-21, 08:10 PM
XSleeper's Avatar
Received 1,844 Upvotes on 1,659 Posts
They changed the formulation some years back, so I doubt its as good as it once was, but Westley's Blech-wite used to be the bomb for cleaning stains off gutters. Its a white wall tire cleaner. Wet it, let it soak, scrub it, rinse & repeat.
But the finish on gutters that old might be shot by now.
MonteCarlo voted this post useful.
Old 06-09-21, 09:17 PM
Received 128 Upvotes on 113 Posts
There's mold all over everything.
I'd spray it down with bleach and water 50/50 with a pump sprayer, or use a pressure washer with the spray nozzle and use bleach on the suction line, wait an hour then pressure wash it.
Old 06-10-21, 02:12 AM
Marq1's Avatar
Received 1,210 Upvotes on 1,098 Posts
Agree, tire cleaner is what I use all the time. I use one of the large industrial spray bottles and a brush like this and it cuts right through all the grime that collects on the gutters. They have theses at Lowes!
Old 06-10-21, 04:11 AM
Received 800 Upvotes on 703 Posts
I usually spray a bleach solution on it, let it set but not dry and then use a pressure washer to rinse it. When that doesn't get it good enough I often use 409, Greased Lightning or similar and hand wash.
Clean aluminum paints well so that is also an option.
Old 06-10-21, 05:41 AM
P
Received 2,009 Upvotes on 1,801 Posts
Because of COVID I couldn't get bleach or outdoor cleaners with bleach to do my sorta regular house pressure washing. This spring I tried just with a pressure washer and it got 75% off but you could still see the mildew when you got within 10 feet. I used Clorox Outdoor Bleach in the strongest mix they recommend and the gutters were mostly white even before I pressure washed. The key is to spray the cleaner on while the gutters are dry. Give it a few minutes but make sure to pressure wash before it dries.
I have tried bleach alone and it works about as well as the outdoor bleach on mildew. I notice that the outdoor cleaner does better than bleach when there is dirt or bird poo to remove.
Old 06-10-21, 04:15 PM
Thank you all very much for the great suggestions.
