Best way to get rust off an intricate key
Old 06-24-21, 10:29 AM
Received 4 Upvotes on 4 Posts
Metal polish like simichrome is difficult because there's no smooth surface to bear down on, any sort of brush scrubbing whisks away the polish
Old 06-24-21, 11:11 AM
P
Received 2,108 Upvotes on 1,887 Posts
I would use an ultrasonic or vibratory parts cleaner. If you don't have access to either of them I'd just use some polishing paste and an old toothbrush or wire brush. Of course it will rust again since the polishing will expose even more unprotected steel.
Old 06-24-21, 11:14 AM
Received 3,892 Upvotes on 3,489 Posts
There are many commercial rust removers you could soak it in. PB Blaster is one.
You could also mixing water and baking soda into a thick paste and put the key in that.
Old 06-24-21, 11:38 AM
I have plenty of PB Blaster, I'll use that, thank you
Old 06-24-21, 12:36 PM
Marq1's Avatar
Received 1,210 Upvotes on 1,098 Posts
Just drop it in a paper cup with some vinegar!
