Question how to clean and maintain faucets and showers
Old 08-29-21, 07:07 PM
H
Hi how do I maintain my faucets and shower heads? I have pics attached. I have White or green buildup - any thoughts?
thanks
Old 08-29-21, 10:44 PM
Received 129 Upvotes on 114 Posts
Get your water tested, it Likely needs to be treated to get rid of the minerals so it does not cause these issues.
Old 08-30-21, 03:06 AM
Norm201's Avatar
Received 727 Upvotes on 643 Posts
High calcium build-up. But the question I have is how long does it take to get this way between clean up? Hard water is the culprit, but short of getting a water softener, daily clean ups will solve the problem. After every shower we squeegee the walls and wipe down all the fixtures.
Old 08-30-21, 09:30 PM
H
Any recs
Any recs on what to use to get rid of calcium build up?
is there a recommended polish we can apply?
we do squeeze the glass doors but did not think of the walls..
Old 08-31-21, 07:00 AM
Norm201's Avatar
Lime-A-Away, CLR or similar. Both available at almost any store.
You should also squeegee the the walls. The more moisture you remove the better. I hope you also run the exhaust fan before, during and after using he shower or bath.
