In my greenhouse I have vinyl "gym" flooring. In areas under a fountain and near the sink there is a white residue probably from minerals in the water. The area by the fountain does not get wet but minerals evaporated into the air apparently settle onto floor and adjacent window glass. (I notice the same effect near my vaporizing humidifier in the bedroom. Both the fountain and the vaporizer use tap water.) The spots by the sink are spills and may also have some insecticide in them. I need some suggestions about cleaning them and a finish for the vinyl.
Area below fountain. The darker area has been brush scrubbed with white vinegar and rinsed and is dry. Close up of boundary between scrubbed and not scrubbed areas showing some residue. Area near sink. These spots do come off when scrubbed with soap, water and fingernail.
Once this residue is removed, what type of finish should go on the vinyl to brighten it and make the appearance consistent across the entire floor? The floor is under plant benches for water resistance and is not a walked-on surface.
Hello, I just found out my dishwasher drain or pump was leaking and I can see subfloor water stain from basement with a few mold spot. I have removed the floors with the paper layer underneath the hard wood floor. It seems to me that is the edge of the water damage. Then I sprayed the subfloor(polywood) with Concrobium. I will let it completely dry first then will follow the Concrobium instruction for next step. I think will be mop it with wet cloth. Based on the position of the water damage, I would think I will need to cut a piece of the bottom board of the cabinet to see if any mold there. Anything I am missing here? Any insight is highly appreciated. Thanks!
[img]https://cimg3.ibsrv.net/gimg/www.doityourselft.com-vbulletin/800x608/ck1_fdf78a187fe16e892ffad2c915ca5964a1b9fea8.jpeg[/img]
[img]https://cimg4.ibsrv.net/gimg/www.doityourselft.com-vbulletin/800x610/ck2_d9a0fbea41c9921d9ea556e1df5e0cf6481924e2.jpeg[/img]
[img]https://cimg6.ibsrv.net/gimg/www.doityourselft.com-vbulletin/800x594/ck3_6d01b4c038de2b04e54a64a18deb4cb4f43f5d8f.jpeg[/img]
[img]https://cimg7.ibsrv.net/gimg/www.doityourselft.com-vbulletin/800x608/ck4_765ec61163f89cb3d994812229137ba3b5ef0a18.jpeg[/img]Read More
I'm going to try and fix up the aged marble (it is marble, I checked) surround to my bathtub. First step: remove an impressive coating of built-up soap scum and limescale. I've got a bottle of ZEP:
[img]https://cimg9.ibsrv.net/gimg/www.doityourselft.com-vbulletin/605x806/img_1509c_044c44011b56ce0a9eb683037d2d59c4cfca8b6c.jpg[/img]
What's good about it:
• it's inexpensive.
• the spray head does produce foam.
• the foam does cling to surfaces. A bit.
• after clinging, soaking, [i][u][b]it is effective[/b][/u][/i] in removing the buildup.
Great.
Problem:
[img]https://cimg8.ibsrv.net/gimg/www.doityourselft.com-vbulletin/605x806/img_1508b_9ab5219d6f4745a333f93e6129cbf7d954f3eeb7.jpg[/img]
Even though I have tried several times to spread the foam evenly over the area on which I'm working, gravity always does its thing and the foam starts to run down the wall (vertical, duh) in streaks, so when I wipe it off, I'm left with a look that would be great on a horror movie set, but looks like hell.
What I need is a way of evening the 'cling' of the foam.
Any ideas?
I suppose i could sit there and every two munutes or so, get the sponge and re-distribute the foam, but i can't help thinking there must be people who do this often and have found a smart way to do it.
Thanks,
Read More
