What would be the best solution to dissolve Fluoride buildup
Old 06-10-22, 08:33 AM
I have like a disk of it at the bottom of my water distiller and it's quite resistant to my m18 impact wrench with wire wheel.
Old 06-10-22, 09:04 AM
P
Received 1,852 Upvotes on 1,658 Posts
It is most likely not fluoride and more likely to be mostly calcium and maybe some magnesium. I would use an acid if your distiller is glass or stainless steel. Do not use an acid on aluminum. You can start light and try soaking it in vinegar or CLR. If you want to hit it hard you can use a muriatic (hydrochloric) acid solution. Make sure you read the label and follow the safety precautions as it is a VERY strong acid which can be dangerous.
Old 06-10-22, 12:44 PM
Thanks. I'll continue working with vinegar. And hopefully keep up on maintenance but it's easy to let it build up. Whatever it is can't believe people used to let it go through their bodies.
Old 05-24-23, 05:38 PM
Must wanted to update this in case anyone reading also had this issue:
Vinegar and water, run a couple cups through as needed. Softens the buildup so you can easily wipe it out and not have to use power tools lol
