Surface cleaning wall tile
Old 05-13-24, 08:33 AM
T
Received 1 Upvote on 1 Post
I知 interested in some wall tile cleaning equipment that is similar to what is used on floors / concrete with a pressure washer and a spinning wand with several spray heads. Rotovac is a company that I think makes these type cleaners. Very low water consumption and a port for wet vac connection. Anyone have experience with these? I知 looking to use this to clean shower walls. There are some local companies for hire but I知 inclined to purchase the equipment myself for use / reuse. I have access to an electric pressure washer that is adjustable that may be suitable for this application. We池e on a septic system so I try to avoid harsh cleaning chemicals. Any input is greatly appreciated.
TF
Old 05-13-24, 12:02 PM
Received 4,059 Upvotes on 3,642 Posts
Not a pro on this just making some observations....
I'm guessing kitchen backsplash and shower/tub tiles ?
I couldn't see using a pressure washer on any type of inside tile cleaning job.
For years I've used Kaboom tile cleaner. It did 95% of the cleaning work.
I have a battery operated rotary scrubbing brush that works great for the corners.
I use a scrubbing brush on a handle for the straight walls.
I know there are good machines for cleaning floor tiles but not for walls.
A pro steam cleaning machine might be a good choice.
