cable lines
cable lines
if i am to splice cable line to add an extra outlet for a bedroom, are there any issues that need be considered? i have already bought an amp for the cable line and plan to use it also.
If I understand you correctly, you will have 3 TV's total? That shouldn't be a problem. You shouldn't even need the amplifier for the line. If possible, you would be better making all your splits at one place. In other words, instead of using 2 - 2 way splitters, use 1 - 3 way splitter. This will give you the best signal to ALL your TV's.
Unless it was done by you or a previous homeowner, usually the cable company will split at the box, depending on how the house was wired and everything too.
