Grounded Phone Line ????
Old 01-25-03, 09:31 AM
wingnut2
I was replacing phone lines in my house, and when I got to the terminal block in the basement, the green and red were attached to their respective posts, but the yellow conductor had been attached to a grounding post that is grounded to our water pipe. The black conductor wasn't attached to anything.
Is there any logic to grounding this yellow wire?
If I were to have the phone company put in a second phone line, that would use all four conductors, and I certainly wouldn't have a ground wire then, so I'm questioning if that wire should even be connected to ground.
Thanks for any input
Old 01-29-03, 07:56 AM
garmtn
Question ground wire
You're correct. No reason for the yellow to be grounded. Years ago, princess phones picked up a hot leg for lights. Then stricly powered by lines. Remove it. By todays standards "quad" isn't enough. You should have at least 6-pair feed and 4pair to your jacks.
