wiring and caller ID
need some opinons. I had a second line installed with the caller ID feature. I have a cable that runs from the tel. co. d-marc on the side of the house to a 66 block in the attic. From there the house was prewired out to each room.
I hook up a phone to the new line & get no caller ID but I do get dialtone & calls. The phone LCD reads out as "line error" or "no data sent". I use the phone on my primary line and can receive caller ID fine, so I know it's not the phone. I take the phone outside & plug into the NIB and walla! I have caller ID. The problem obviously has to be in the cabling but I would think if I have a working pair I would have caller ID also.
Should I check for excessive resistance? The volume on the line seems low, even if I crank up the phone volume to MAX. Should I just try another pair?
thanks in advance,
Hal
thanks in advance,
Hal
Received 0 Votes
This is a common problem with adding too many extensions and too many devices on 1 line (I've seen this happen after installing a security system in a house.) I forget exactly what does this (resistance, capacitance?), but basically what it boils down to is that the Caller ID signal is not getting through (I know it's sent between rings 1 and 2 - at least, that's what I was told by Tech Support when I called about it - how that helps, I have no clue.)
Now, all that to say, I'm not sure of an exact solution, other than removing devices from the line and getting a more "direct" line to the phone. There may be a device out there that will amplify the line some to help, but if there is, I don't know what it's called or where to look for it.
I think I would start by calling the phone company to see if they have a solution (or maybe they could even increase the signal to your house?)
Good luck!
Good luck!
