fax/phone dialtone
Old 03-09-04, 01:57 PM
moffatt
fax/phone dialtone
can someone please help me. I have a fax/phone that will recieve incoming calls, but when I try to call out I get a couple numbers dialed and then hear a bong and that kills the call
Old 03-09-04, 05:56 PM
Received 236 Votes on 216 Posts
Sounds like you may have some kind of speed dial set as the default. You might want to peruse the instructions. A lot of these machines have special keystrokes to use it as a normal voice phone.
If it's a hand-me-down, most of the major manufacturers have their manuals as free downloads online.
Old 03-09-04, 06:22 PM
It sounds almost like a PBX type setup - if you don't dial 9 first, you get the long tone. Something similar to that. As MrRon mentioned, you may need to change some settings.
You could also try resetting the machine if you can find out how.
Tell us a little more about it and we'll see if we can find some info on it.
Good luck!
Old 03-10-04, 01:45 PM
moffatt
fax/phone
Thanks for the help people. I'll investigate a little further and let you know how I make out. Thanks again T
