CAT 5 & Coaxial Tester?
Old 03-16-04, 08:04 AM
pw1972
Im finishing my basement and have about 8 runs of coax for cable/sat and 16 runs of cat 5. I'm wondering if anyone has any recommendations for a lan tester for these or some other easy way to test the connections? Locally I can't find a tester for anything less then like $80, I've seen some online but am concerned about buying a cheap $30 item.
If I buy a device to do this it's probably going to be a one time use, but would be handy to have around, so I don't want to spend more then $40 on it.
Any recommendations?
Thanks
Paul
Old 03-16-04, 06:10 PM
Received 236 Votes on 216 Posts
Check your local tool rental places. A couple of them locally have them, some electronics stores have them for rent, as well. (admittedly, this is a college town).
Old 03-26-04, 09:51 PM
www.compgeeks.com often has one for about $20, but I can't find it on their website right now. I have it and it works fine. The $30 ones you are finding on the net will probably work. They are not a complicated tool.
Old 03-29-04, 07:11 AM
pw1972
Thanks for the info. I ended up getting one for about $40 and after getting it was amazed that these are nothing more then glorified continuity testers. Still useful to have, much easier then lugging a computer down there to test it!
Thanks again
