moving "powershield"
Old 03-24-04, 09:02 AM
A
I am going to be finishing my basement soon and started doing prep work. I found this thing in my basement it is from APC and it is a power shield.
If I leave it wher it is I am either going to have to cover it up perminantly or create an access panel neither of which I want to do. So I want to move this to a place in the basement that isn't goin to be finished.
It is attached with a 22awg wire with a 6 pin connector
What I want to know is
(1) can I splice into this ? If so what type of connector do I use to butt the two together.
(2) should I try to run it from the IAD to the new location and for get the splice
(3) should I even attempt his or will this render the equipment useless.
Thanks for the help
Old 03-30-04, 10:52 AM
A
I contacted the vendor
I found out that this product was made by APC. I emailed their tech support and it will be safe to move it.
Basically this is a battery back up for the VoIP system.
Thanks for trying to help
Old 04-01-04, 05:26 PM
Sorry we haven't been able to help - but I'm glad it worked out for you. To be honest, I had no idea what that could have been. It didn't sound like a normal UPS system, but I guess it is
That's why they call it Do-It-Yourself - maybe next time we'll be more help. BTW, when you're posting, be sure to include any model numbers and anything else you might think will help us out.
Good luck!
