Faulty battery or cellphone??
Old 04-29-04, 03:58 AM
Static
Sometimes i charge my Nokia 2100, when it gets full the phone will automaticly turned off. And i'm no even sure if it's full. This happens every 2 or 3 charges. And I can't seem to turn it on again after that. So i will have to take out the battery and put it back, which is a hasssle. Or i will turn on the charger again. Even if I do so, i will still have to set the date and time. But the battery is still attached. So what is the problem here??
Old 04-29-04, 07:31 AM
WorldBuilder's Avatar
Well, you're right. It's either a bad battery or a bad connection somewhere in the phone. To test, take the battery to the store and (if it's under warranty) have them replace the battery. See if that solves the problem. If it does, you know it was the battery. If it does not, then it's the phone in which case I'd say it's time for a new one.
Chris
