2 out of 4 is bad
Old 07-07-04, 08:27 PM
sixpackbaker
2 out of 4 is bad
I have 4 phone jacks in my house.
2 are connected to a network interface system (both uses the red and green wires connected to 'Line 1' via screw down) and the other two are conncted to an old system (it has a ceramic base with a black button-like thing).
The 2 jacks that are connected to the old system work but I get no dial tone with the other 2 (i tried both the jacks and plugging the phone directly into the NI).
My question is how can I get all four jacks to work on the same line?
please help.
Old 07-08-04, 06:58 PM
You need to call the phone company - they did not make the connections outside the house correctly. Your NID should be where your dial-tone is at. I believe it's also their responsibility to move the old lines from the old connection to the NID, but I may be wrong about that.
I would have them come out and check it out first - you should definitely get dial-tone at the NID.
Good luck!
Old 07-09-04, 12:43 AM
irsean
They're not actually required to move lines from one NID to the other. They probably will if you ask them but, if you call them out there will be a charge. The first question I have is: Are the NIDs close enough to move the pairs over yourself? If not, you can run a pair from the working DEMARC to the inoperative DEMARC (NID). When you refer to one terminal as NID (Net Interface Dev) and the other as "screw-downs", I assume one is a grey (plastic) box and the other is just a couple of threaded posts and screw lugs (probably a couple of fuse like things: carbons) with the working pair at the newer, plastic NID and the inop pair at the screw type terminals. Disconnect the drop (telephone company pair) from the screw-type and tie a pair off of the bridging pair that was ran between the two NIDs. Otherwise, it's a rewire.
You can buy a phone line tester from Radio Shack that will tell you if you have polarity (Tip and Ring) correct.
