Wiring cat3 phone line?
Hi all,
I know how to run and crimp CAT5e cable. I am running some phone wire (cat 3), though and don't know the color codes or how to crimp them down. Could someone show me a diagram on how to wire the FOUR pin cat 3, please? What I mean is: There's red, green, black, and yellow. I know (well, I think) that only the red and green are used. Where do they go? In the four pin end connector, what is the scheme?
I'm just putting rj-11 jacks on each end of the cable for now to test. How do I do it?
Thanks!
Chris
PS. I've googled all over the place, but for some strange reason I can find nothing...
Thanks!
Chris
Ok wait...
I have been misinformed, and am confused. I'm sure I sound like a dolt, but here goes.
Apparently phone cable and cat3 are NOT the same thing. Right?
Well, I bought cat3 cable and ran it throughout my house. Now, this cable right now has no ends of any kind, it's just cable lying around. I ran some of this cab;e through an unfinished ceiling. Now, before I put up the drywall ceiling, I want to test the cable to make sure it all will work and isn't damaged. Makes sense, right?
Ok. I THOUGHT that phone cable and cat3 was one and the same. As stated above, it's not.
Apparently phone cable has 4 wires: red, green, black, and yellow.
Apparently, cat3 also has 4: blue, white/blue, orange, and white/orange.
Now what I want to do is just put male connector ends on the cables for now to test. So, I bought some of these male connector ends. They are 6 position, not four.
I called General Cable from Home Depot and the guy said that the wiring scheme is as follows:
pin1 - empty
pin2 - WO
pin3 - B
pin4 - WB
pin5 - O
pin6 - empty
Is that right?
Chris
pin1 - empty
pin2 - WO
pin3 - B
pin4 - WB
pin5 - O
pin6 - empty
Is that right?
Chris
Are you putting male connectors at each end, and not a female jack at the use end?
I mean, it will work in the sequence you have laid out. I'm just curious about the male ends on the drops.
For most installers on the solid/stripe color twisted pair wires, they use the light color for ring (red) and the solid for tip (green). You will find individuals that reverse that, but that's as close to a standard as you get.
Eventually one end will be a female jack, yes. The other end goes to the NID, right?
BUT, for right now only, I am simply crimping on male connectors on both ends just to test the cable. What is the wiring scheme?
Chris
Chris
Finally found what I was looking for. I think this is what I want:
http://www.ablecomm.info/wiring.htm
Chris
Chris
I made and tested the wiring today using the color scheme from that site. It all tests fine. I've also heard that consistency is key in this wiring. Just make sure that (when wiring the NID) everything is consistent and is hooked up to what it should be hooked up to. Makes sense to me.
Chris
Chris
Ok, so is it as simple as this?
One end of the cat3 cable is punched down at the jack in the wall. The other end gets punched down in the NID. Is it that simple?
Chris
Chris
I haven't really even looked INSIDE the NID yet, but usually how many connections can you make in there? I figure I'm going to have 5 jacks total. One line. Will there be enough in there, do you think?
Chris
Chris
Depending on the type of NID you have, you should have no problems. Most have screw terminals to wrap the wires around. But, lately they have started using a different type that has a snap-down connector. If that's the kind you have, then you'll only have 3 or 4 connection points - you may have to just jumper some wires or something. There are several options. Just make sure all the wires are connected on your side of the test jack and you'll be fine.
Good luck!
Good luck!
I'll let you know how it turns out and ask more questions if I have 'em.
Chris
PS. Just thought of one... Am I allowed to move the NID from where it is currently attached (on the side of the house) and move it into my basement, or does someone qualified (ie, the phone company) have to do it?
Chris
Ok, one more question.
Is there any reason to NOT have it on the side of the house? Is it ok there? If it is (and I'm just making a big deal out of nothing), lemme know and I'll leave it right where it is.
Chris
Chris
If you're worried about someone tampering with it - don't worry. If they want to mess with your phone lines, there are plenty of places between your house and the CO to do so. If that's your only reason for moving it, just leave it.
if your worried about somebody gaining access you could also build a enclosure around it evan put a lock on it or use tamper proof screws
the telco dosen't need access to it if they want to disconect you they do that at the CO
Tampering and weather are the only reasons I wanna move it. Ok, so tampering is no worry. Weather? Leaning towards leaving it...
Chris
Chris
