Add Phone Jack
Old 12-08-04, 12:39 PM
mlstle
Add Phone Jack
I'd like to add a phone jack next to a RJ-31X. I have 3-pair wire and 2 pairs are used for the RJ-31X. What's the best way to accomplish this?
Thanks,
Marnie
Old 12-09-04, 12:24 AM
D
You should be able
to tap off at the jack itself, unless I'm not understanding what you'd like to do. You should just be able to run your new wire from the RJ-31X to your new jack.
Here is some general info on phone systems wiring:
http://www.safewatchservice.com/phon...73ecd6d7dfd008
Good Luck!
Old 12-09-04, 04:15 PM
Received 285 Upvotes on 262 Posts
Just remember to tap the new jack from the outgoing side of the rj31X (brown/grey) Otherwise you compromise the ability of the alarm to sieze the phone line even if a house phone is off the hook.
Old 12-09-04, 04:29 PM
mlstle
Thanks, I got the line working but hadn't tested it with the alarm system. I'll change it to the outgoing posts.
Marnie
