Connect USB and Ethernet on 1 cable modem?
Old 03-18-05, 05:12 PM
houseman's Avatar
I have a Motorola SB4100 cable modem, from the cable company, and it's connected to the Ethernet port on my PC. The cable modem also has a USB jack.
Can I run a USB cable from the modem to a second PC, and get the internet on both PC's simultaneously? Or should I get a cable router?
Thanks!
Old 03-19-05, 05:00 AM
mango man's Avatar
your going to need a router
Old 03-19-05, 03:23 PM
Lugnut's Avatar
You can use either the USB port or the Ethernet port, not both. This accomodates users who do not have an Ethernet card, thus may use the USB port.
Old 03-22-05, 02:47 PM
houseman's Avatar
Thanks for the advice. Looks like I need to install a router...
Old 04-07-05, 06:30 PM
gcgrimes
Both ports at same time...
Problem with using the Ethernet and the USB at the same time is that the cable company only provides 1 IP address per cable modem. If that 1 address is in use for the Ethernet port attaching the USB would be non productive. Invest in $40 router and connect up to 4 PC's. A bargain at the price. Hmmmm... it's been a week since I checked they may be cheaper again.......
Old 04-07-05, 06:44 PM
kaybyrd's Avatar
You can use both ethernet and usb...if you are running a linux box off the ethernet and a windows box off the usb port!
Found that out while running Linux on the desktop and windows 98 on the laptop.
Kay
Old 04-08-05, 08:18 AM
houseman's Avatar
Both PC's are Windows, but it's good to know that you can run windows and Linux PC's off of the same cable modem!
I put in a router...you're right, it was $40 at Walmart.
