Adding a second phone jack
I have three wires coming in from the telephone company's box outside that go to three rooms in my house. All three are on the same phone number. I want to add a new jack to another room with the same phone number.
I bought a wire that has 4 colored wires inside (red, green, black, yellow). I hooked the new wire to the back of an existing jack that has the same colors. This existing jack now has the red, green, black, and yellow wires from the line coming in from the outside and from my new wire. I then took the new wire and hooked up all four colors to back of a new jack.
The phone does not work on my new jack, but still works on the existing jack.
What did I do wrong?
Received 0 Votes
Most likely, the red and green wires are what your phones use. You need to be sure that they are connected to the two center prongs of your new jack. It's possible that the new jack is oriented differently than the old. If you unhook the new jack, maybe you can take an ohm meter and verify which terminals on the back go to the center prongs. Then connect red & green to those.
hate to see you use that junk I/W (r-g-bk-y), but since you have it, connect the Green wire to the green of the jack, the Red to the Red of the jack.. that's where the dial tone should be!.. if the jack is working where you are connecting "from"... you don't have to bother with the bk/y wires, they shouldn't be connected or used since there is only one line.. if your planning on using this for a modem or data, get rid of this I/W and get yourself some CAT5 I/W and run all the way to the NID on the outside of the house.. use the wb/bw pair and connect to the G/R of the jack..
