Adding a Phone to my Workshop
Old 06-04-05, 09:43 PM
twoseas's Avatar
I'm running cat5e to a workshop in my backyard to use for a phone.
I have the following questions:
1. I'm going to install one end of the cable directly into the NID. Is this acceptable...do I piggy back (place over the top) of the existing wires inside the box ??
2. What color wires do I use for this installation ??
3. How do I transition the workshop end of the cable into a wall plate that will accept the smaller phone jack ??
Thanks in advance....
Old 06-05-05, 06:38 AM
mango man's Avatar
it should be direct bury cable , bonded and grounded at both ends , no need for "cat5" if its only for phones .
there should be a grounded nid at each end of the run .
what I would do is install a properly grounded nid next to the existing telco nid and then a jumper from the telco nid to the remote building nid .
when you get to the remote building you would use regualr phone wire ( cat3-5 ) to go to the jack/jacks of choice .
you would use the white/blue pair.
Old 06-06-05, 09:49 AM
http://www.homephonewiring.com/clr-code.html
Old 06-11-05, 09:35 AM
sandbagger's Avatar
is this strictly so you have a phone in the workshop? ie, do you need to connect computer? if only for phone have you considered one of the newer cordless phone systems? how much distance from the house are we looking at? the new 2.4 & 5.8 gig multi-station systems are great for adding extensions without wires. most have the added bonus of also working as an intercom.
Old 06-11-05, 06:38 PM
R
Before you do this, what type of power do you have to your workshop? You may not safely be able to run a phone line to your workshop without changing the electrical wire.
Old 06-11-05, 06:43 PM
twoseas's Avatar
I ran 2 Cat5 cables to the workshop, one for phone and one for networking.
I've completed the installation, both the phone and ethernet are operational.
Thanks to all for your advice....
Ray
Old 06-12-05, 06:36 AM
R
Do heed my warning about the electrical. If you made a mistake you could get killed.
Old 06-12-05, 07:05 AM
mango man's Avatar
BOb
what exactly are you refering to electricly that could be fatal ?
Old 06-14-05, 08:47 AM
R
You do not want your electrical wires anywhere near the phone wires, and you do not want to run phone wires unless your electrical to the outbuilding is properly grounded.
