phone line
Old 06-11-05, 06:35 AM
goow
Thumbs up phone line
Thanks to all for your help I'm going to call the phone company maybe they didn't understand what I needed done.
Old 06-11-05, 06:21 PM
ampz's Avatar
In most cases the TelCo is responsible service/repair for the wire until it goes into your house.If it needs replacement you'll have to call them,otherwise you could be in for trouble with them & the FCC for unauthorized work.
Old 06-11-05, 06:36 PM
R
What do you want this type of wire for? You cannot replace the wire from the pole to the house yourself, so it can;t be for that. Your use will determine the type of wire you need.
Old 06-11-05, 07:56 PM
mango man's Avatar
aerial drop cable
from the pole to the nid/demarc is regulated which means only telco authorized personell can work on it
you could however use it to run bldg to bldg on your own property on the customer side of the demarc
Old 06-11-05, 09:32 PM
goow
Thanks. I built an addition on my house and now the phone line is only two feet off the ground the phone co. said to splice it myself.
Old 06-12-05, 06:39 AM
R
That's their job. Make them come out and do it. If it's on their side of the NID then you cannot even legally do this. Plus, if you climb the pole you are breaking the law.
I would report them to the state public utilities commission for even suggesting something this ludicrous.
Old 06-12-05, 08:17 AM
Whoever you talked to at the phone company didnt know what they were talking about. As what was already said, this is illegal for a homeowner to do and is the responsibility of the phone company.
Old 06-13-05, 11:51 PM
frhrwa's Avatar
give them one more opportunity to come out and take care of the problem, then turn it over to the PUC, telco's "hate" PUC complaints! and it WILL get action..
