2nd Phone Line using CAT5
Old 07-25-05, 11:33 AM
jdroba
I have a new home I just moved into with structured wiring thoughout. All my phone lines use CAT5 and connect through a central pucnhdown box. I have 2 phone lines in use. B/BW is the first line and O/OW is the 2nd line. I have a single phone line (CAT5) run to the closet in my office for my fax, which I want to run on the 2nd line. Is there a way to connect ONLY the 2nd line (O/OW) to this data port only? I use the B standard for all my data. Should I be using the A standard for the phone jack since this allows the 2nd pair to be the outside cables to the primary pair?
Thanks!
Old 07-25-05, 06:00 PM
You can use RJ-45 jacks for phone as a phone plug will fit into them but I would really advise against that and use RJ-11 jacks (they will still hold up to 3 lines).
Reason being is that even though an RJ-11 plug will fit into RJ-45 jack, the connection doesnt have the proper support and you may find connectivity issues later on.
Old 07-25-05, 06:22 PM
mango man's Avatar
wire both voice and data to the A standard then jacks can serve dual purpose.
you can use rj45 for voice , it works just fine, in fact current structred cabling standards call for rj45 for voice as well as data .
