Removing Phone Jack
Old 08-22-05, 04:45 PM
karemik
Removing Phone Jack
We are in the middle of a remodel and need to remove a phone jack but do not have a clue what to do. Any suggestions?
Old 08-22-05, 07:20 PM
mango man's Avatar
if its a single cable tape the individual conductors up (so they dont short out ) then tuck the wire in the wall or ceiling or whatever
if there are two , cables then most likley one is feeding in and one feeding out to another jack so you need to splice all the conductors together before you elminate the jack , otherwise you may kill a jack or jacks downstream.
if the wall needs to be removed the same applies , single cable no problem , two or more cables should be spliced to give you continuity downstream
