Can I do this?
Old 10-11-05, 10:29 AM
Can I do this?
I recently purches a townhome where only two phone jacks worked. The ones that don't work do not have the wires connected to the jacks. What I noticed was that my house seems to have all of the jacks wired in series which I understand is fine. At each of the unworking jack sites the insulation was stripped from the wire exposing each individual wire. Then short lead wires were sodered onto each indiviual wire so that it could be connected to the jack. Well all of the lead wires are to short to reconnect to the jack.
I want to know if I can cut the main wire so I can remove the mess of sodered wires and then reconnect both the ends of the wire to the jack and have the jacks down the line still work?
Old 10-11-05, 10:43 AM
mango man's Avatar
yes you can ,
best would be to use these http://www.3m.com/market/telecom/acc...or_chart.jhtml
availible at home depot or lowes , some hardware and maybe radio shack
use ur2s they have three slots do the two wires to be joined plus a pigtail to feed the jack
Old 10-11-05, 11:02 AM
Thanks Mango Man.
Would this cause problems if I have DSL?
Old 10-11-05, 11:42 AM
mango man's Avatar
dsl will be fine as long as you properly filter it
Old 10-11-05, 11:45 AM
Thanks for your help! I'm going to try it out tonight.
