NID questions
Old 10-29-05, 06:02 PM
Gizzorge's Avatar
Question NID questions
Hi all,
I moved into a house this past summer and have had occasional static in my phone lines. It is always there, but some days are worse than others. Today I ran a brand new line from the NID to the garage. Static is still there.
So I took the phone out to the NID and plugged it in. It was extremely crisp and clear. However, I noticed two things:
1. The screws in the NID that hold my wires in are rusted. Is this my problem or Verizon's?
2. For some reason, the ground wire from the NID is not connected to the ground wire from my electrical service. It's just hanging there. Again, is it my problem or Verizon's?
I just don't want to call them and then they charge me $100 to fix it.
Thanks!
Old 10-29-05, 06:58 PM
mango man's Avatar
the ground issue is theirs . the rusty screw terminls arent likely to cause problems . and would be easy enough to clean if it concerns you .
Old 10-30-05, 06:44 AM
nynextek
The Entire NID is Verizons problem but the Static is coming from your end. If you plugged the Phone to the NID and got a clear line then It is indeed your trouble. You could have them replace the NID and they can't charge you. If you go that route I would advise that you be around when the Tech comes and make certain they replace the NID. A quick question, Was the static ONLY on the line going to the garaged or ws it on every line. If it was only the line going to the garage then it may well be the rust causing the trouble.
Old 10-30-05, 07:29 PM
Gizzorge's Avatar
Question
For clarification, I only have one telephone number (only one line in that sense) and I have two lines (or branches, I guess) from the red and green terminals at the NID.
I have had static since I moved in, and I originally thought it was a loose connection under the house. So I ran my new garage phone straight from the NID. Same intermittent static.
Old 10-31-05, 03:41 PM
nynextek
Static
If you have had intermittent static since you moved in then it may be the drop wire (Service Wire) or a bad cable and pair (both of which are Verizons problem). Does the static come immediately after rain? If so it is more than likely a verizon trouble. If the Drop wire looks old then have them replace it. If you do call for service you must tell them you had an outside vendor run all new wiring and it's still static so this way they will either change your drop and/or change your cable pair and won't try to hit you with a service charge. Strees the fact that it is an intermittent trouble in case the line tests "OK" when they get there.
