Removing old rotary wall phone
Received 0 Votes
Hi- I know many of you like the old rotary phones, but I'm getting tired of it and with dsl I can't use it until I get a filter on it so it's time for it to go. I removed the cover, and it looks like the plate is held on with screws, but then what? Is it easy to install a jack for a newer corded wall phone, or will I get electrocuted doing this myself? Thanks for any assistance!
Welcome to the forums
Installing a new phone jack is easy. I'm not smart enough to know if there is any current in phone wires but at any rate it isn't enough to hurt you if there is current. Both the phone wire and the new jack are color coded so it is easy to tell which wire goes where.
Here is site with good info on phone wiring
'removed bad link' - see post #11
maybe becouse
File not found
Firefox can't find the file at /C:/Documents and Settings/mark/My Documents/Doing your own telephone wiring.htm.
* Check the file name for capitalization or other typing errors.
* Check to see if the file was moved, renamed or deleted.
File not found
as to the orginal question , just unscrew the phone from the wall and replace it with a phone jack
you wont get electrecuted but if you happen to be holding the bare wires when the phone rings you will get a tingle .
there are two wires bringing dialtone in , either red and green or blue ane white blue . thats what you attach to your new jack .
:confused:
Am I doing it wrong? When I copy and paste it to the address bar it brings it up for me. I know I'm kinda dumb when it comes to computers but was just trying to relay a web site that someone here gave me a few weeks ago when I had to change my phone wiring
Originally Posted by marksr
It works with IE
My phone wires have red & green - line 1, and yellow& black - line 2
oops though I was responding to the OP
like Joed said your link is to a file on your computer ...(I should have cought that )
http://www.ling.upenn.edu/~kurisuto/phone_wiring.html
I went back to the post where I originally got the link, hopefully I got it right this time.
It's hard to teach an old dog new tricks - maybe someday I'll get this computer stuff figured out
