Why so many colors and what do they all mean?
Received 0 Votes
I have a phone jack about 5' off the ground (it was behind a wet bar that I removed). The wire bundle (12 total) comes from above. The wires connected to the jack were blue/white, white/blue, brown/white, and white/brown and have no extra length. (This jack used to support two lines back in my dial-up days.) There are 8 wires rolled in a bundle that appear to have enough length to reach close to the floor. Can any of these be used to make a live jack? Thanks.
If this mass of wiring circulates through the house, like mine does, you can use any pair. If you can, connect the new pair at the point where it leaves the NID (where the line enters the house) and put a note on it to remind you and the next owner why and where it's used.
Line 1 is normally blue, 2 is orange, 3 is green, and 4 is brown.
Received 0 Votes
why wouldn't you just continue to use the blue white pair ?
there isn't enough voltage to worry about but to be safe you can just disconnect everything at the NID while you are working on it
Received 0 Votes
The blue/white pair was cut at the height of the current jack which is 5' above the floor. The bundle comes from above so if I want to drop the jack down I either have to use a different pair (the unused wires were not cut) or solder extensions to the blue/white pair. Is there any kind of code that makes that a no-no?
