rj 45 coupler
rj 45 coupler
anyone have a link to a .5 foot rj45 male to female couple pre assembled and crimped,quality... cant find anything but the regular plastic thru connectors..basically a pre assembled pigtail
Received 38 Upvotes
You want a six-inch long flexible cable with a RJ-45 plug on one end and a RJ-45 jack on the other end? May I ask why? Wouldn't it be simpler to get a RJ-45 cable long enough to go from whatever you are connecting to the jack?
You may have to make your own by cutting one end off a patch cord and connecting the wires to a female jack (w/punch down block) like a Quick Port insert. Shrink-wrap the jack end.
I wanted a small adaptor to live in the ethernet jack so it does not get worn out by unplugging a cord out of it 5 times a day. I always disconnect when I am finished. good policy.I am wrecking my port. and I want a 1 piece crimped item to avoid loose connections. I have seen what I want before but cant seem to find it at the cables sites...
Hmmm how about just using a little project box and a switch to break on or 2 lines? I could probably dig through parts bins in the garage and come up with what I needed.
Connector
Check out these web sites , *****.net , deepsurplus.com , and tigerdirect.com
