Low voltage brackets
Old 06-04-10, 10:11 AM
I am a little confused on what is appropriate for a low voltage bracket/box (specifically the orange plastic ones with open backs). I only intend to use them for audio (optical, 3.5mm, speaker wires), video (HDMI), and communications (CAT6,5e,3). Would any of these uses be more appropriate for a normal voltage A/C box rather than the low voltage ones?
Old 06-04-10, 12:12 PM
Received 2 Votes on 2 Posts
You can use standard boxes, if you wish, but you are fine with the low voltage boxes for your application.
Old 06-04-10, 02:01 PM
The reason they are for low voltage applications is becuase of the bending radius of the wire. If you try to bend the wires to fit in a standard box, its going to jack up your cover plate and it will look out of wack. None of those wires require the use of a standard box, save yourself the headache and use the low voltage ring.
