Fax Connection
Old 01-27-11, 01:57 PM
E
Fax Connection
I have to connect and reconnect my fax to the DSL router each time I use it, which is not often. I don't want to do that every time, is there another way to connect my fax separately?
Old 01-27-11, 07:40 PM
G
Received 2 Votes on 2 Posts
Could you connecct it directly to a phone jack. Mine works fine that way.
Old 01-27-11, 07:47 PM
E
Not without stringing a long line across the house. I was hoping there would be some kind of an adapter or splitter or something I could use. Guess not.
Old 01-27-11, 08:01 PM
lawrosa's Avatar
Super Moderator
Received 77 Votes on 69 Posts
Plug this into the jack your router plugs into. Then plug in your fax. Unless you are talking about something else? Be more specific with you connections.
http://rds.yahoo.com/_ylt=A0PDoX0PQE...ksplitter1.jpg
Mike NJ
Old 01-27-11, 08:39 PM
tldoug's Avatar
Mike NJ
You can also plug that splitter into the jack on the router. Plug the incoming telephone line into one side. Plug the fax into the other side. This arrangement may reduce wiring clutter depending on the layout of everything in the room.
Old 01-27-11, 09:06 PM
E
I plug it into the router when I am ready to use the fax, but that's what I am trying to get out of doing. It is across the room and I want to have a more dedicated line to use so I don't have to plug and unplug whenever I need to fax.
Old 01-27-11, 09:10 PM
E
A splitter is what I was thinking of. Exactly what kind of a splitter am I gonna look for? Just a phone jack splitter?
Old 01-27-11, 09:13 PM
E
Ohhh, ok I see....now that I saw the pic that u posted of the splitter. Great idea. Thanks, I will try that.
Old 01-27-11, 09:18 PM
lawrosa's Avatar
Super Moderator
Yes thats what it is a phone jack splitter
So your router is plugged into a phone line, and when tou use your fax you unplugg the router phone line and plug in your fax.
If so then use this splitter on your router and plug the router line and fax line to it. No more plugging/ unplugging
Mike NJ
Old 01-27-11, 09:26 PM
ray2047's Avatar
Received 15 Votes on 13 Posts
But the fax machine would need to be on a DSL filter if the router was plugged in. . Most DSL filters have one jack for the router and one for the phone.
Old 01-27-11, 09:39 PM
lawrosa's Avatar
Super Moderator
No he has no phone there. ( so he says) Just router to phone jack????
My dsl router has one line. Router to phone jack. I have a splitter at my phone jack. One for router and one for fax.
Mike NJ
Old 01-27-11, 10:34 PM
ray2047's Avatar
Mike NJ
But it is a DSL filter splitter, correct?
Old 01-27-11, 10:40 PM
lawrosa's Avatar
Super Moderator
Hmm. This is what my router has.
http://rds.yahoo.com/_ylt=A0WTb_qeZE...et3346back.JPG
1---Dsl on router to phone line on wall.
2---Spiltter at phone line on wall.
3---Router goes to one end on wall splitter and fax to another on wall splitter.
What else???
If you have phone do this...
http://rds.yahoo.com/_ylt=A0WTb_4wZk...s/image002.gif
And I dont think I ever saw a phone and dsl jack on a router. I might be wrong but show me.
Mike NJ
Old 01-27-11, 10:46 PM
ray2047's Avatar
The Fax needs to be connected to a phone line not a router. Can you explain that more fully? Any FAX machine I have ever heard of connects to a POTS line to work. (POTS = Plain Old Telephone Service).
Old 01-27-11, 10:55 PM
ray2047's Avatar
What else???
You have to have a DSL filter for the FAX same as with a phone. Otherwise it will interfere with the router working correctly.
Old 01-27-11, 10:59 PM
lawrosa's Avatar
Super Moderator
This thing is the same thing I posted
Its a phone line splitter. I dont care what it says on the outside...dsl/phone. Its a splitter and not a filter. Thats from 1970....LOL
Mike NJ
Old 01-27-11, 11:10 PM
ray2047's Avatar
And if you look closely at the picture there is a DSL filter. There has to be. The sppliter I showed earlier has a built in filter on one jack. The splitter in the diagram doesn't that is why they had to add a simplex filter to the diagram.
Mike NJ
And you probably won't because it wouldn't work if the router was on a home run with the filter at the NID.
Old 01-27-11, 11:13 PM
ray2047's Avatar
That is a filter of the type supplied by AT&T with self install kits.
Old 01-27-11, 11:28 PM
lawrosa's Avatar
Super Moderator
I'm right except when I'm wrong.
OK Then......
Mike NJ
Old 01-28-11, 12:00 AM
ray2047's Avatar
OK Then......
Mike NJ
LOL Gee that was fun. Hope we didn't scare the OP off. Have a good night
