Wiring for phone and DSL
Received 0 Votes
I've seen it mentioned before, can't remember the details.
The story goes that for optimum phone reception, I need to separate the wires running DSL from the phone wires. Details, please. Is this done before the lines enter the house? And what do I do?
Received 0 Votes
Can I assume a NID is this?
And, where does the DSL filter attach?
And what happens when the wires going into the house are blue, orange, white/blue, and white/orange? Like this:
I would put a pot splitter inside the house. Somewhere in your home (likely near your electrical panel) there will be the other end of the line tied into your NID. There will be 2 wires (single pair) that your phones and data are tied into. These wires go into the "Line" slots in the splitter. From there what I have done personally is get a small length of data cable, strip it, cut out a pair and run it to the master slot on a phone block from the "Phone" portion of the splitter. Then I made provisions for my modem to be located by my panel so I just ran a regular old phone cord from the "modem" jack to my modem.
Received 0 Votes
Ray,
I don't believe so. The Grey "door" that's open in the second picture has a "plug" built into it that connects when closed. Otherwise, everything in the box is connected by screw terminals.
(What does NID stand for?)
Mr. Awesome,
Your gizmo looks like it might work. Is this something readily available at Radio Shack?
Mr. Awesome,
Radio Shack, unlikely. You will most likely need to go to an electrical/telecommunications wholesaler. I'm unsure of which companies are big in the states... Graybar? Do you guys have Wesco or Eecol there? Ray could probably recommend a place.
You should be able to buy a pot splitter and a phone block there.
This a phone terminal block:
There is a master port where your wires from the pot splitter go.
Then all your phone lines plug into the rest of them. Keeps it all tidy.
That's a new style NID. Plug is hinged.
The white and blue pair goes into the house. Is there any type of connection block inside that you can see ?
Are you putting the DSL modem at an existing phone jack location ?
You can just plug the modem in directly and then use a filter like in the picture at every phone location where a phone is plugged in. They are available almost anywhere.... Depot, the Shack and many places online like Amazon. They run about 5 bucks each. If you're using a whole house cordless system then you would only need one.
As PJ said it is the hinged jack that is the real problem. Here is an example of an out door DSL Splitter that could be hard wired next to your NID. Outdoor DSL Splitter - DSL Filters & Splitters - DSL and xDSL - Passive - Premise Distribution
Here is another example: Outdoor DSL POTS Splitter
Received 0 Votes
I finally got a chance to work on this. And it's not going as well as I envisioned. I bought a POTS DSL Splitter. Interior. It requires me to cut the telephone line and install RJ11 clips. When I do that, it doesn't work. I've temporarily spliced the wires back together, so I know the line is still good. Are the 4 lines supposed be in a certain order (blue/orange/white-orange/white-blue) when inserting into the clip ends? It was never mentioned on the crimping tool package.
Yes..... the RJ-11 plug is six pins. You will only be using the four inside pins. The outer two aren't used.
The two inner pins are the blue pair.... pins 3 and 4.
The next two pins are the orange pair.... pins 2 and 5.
The polarity of the pairs is not particular for most applications.
Received 0 Votes
Thanks for the info.
I don't why the instructions on the crimping tool couldn't have mentioned that we need to check for proper order before inserting the wires... Now I have to buy more connectors because I blew through six of them thinking that the tool wasn't working right.
I have boxes of them.... too bad you weren't closer.
The tool doesn't usually illustrate the connections but most packages that the connectors come in do.
