Conduit fill.
Old 04-13-15, 05:25 AM
E
Conduit fill.
What size tube do I need for 2x 5.2mm od cable and what size for 2x 5.2mm and 1x 8.6mm?
Old 04-13-15, 06:20 AM
P
Temporarily Suspended
We measure in inches here so it would be a 1/2" conduit. In mm, it would be 13mm. You could always go a little bigger, especially if there are turns. I wouldn't go more than an inch or 26mm
Old 04-13-15, 12:27 PM
E
That works out to about 33% fill by volume, is that a good rule of thumb?
Old 04-13-15, 02:26 PM
P
I don't know if there is a "rule of thumb". I just thought that it would give you some room to move. Is it a straight run?
Old 04-14-15, 07:38 PM
Mr.Awesome's Avatar
Is this Cat6 cable? Generally at work we would only put 3 Cat6 in a 3/4" pipe. This is for ease of pulling though, data cable doesn't like to be handled roughly. I have successfully pulled 7 in one 3/4" pipe but was surprised they passed when tested.
Old 04-14-15, 08:05 PM
Received 2,677 Votes on 2,429 Posts
Generally data cable is not run in conduit.
Old 04-14-15, 08:48 PM
E
This is cat 5e and a small section of 2 5e and 1 cat 6 and its in a conduit because it's being run outside for ip survailence.
Old 04-14-15, 09:03 PM
P
He needs that in mm not inches. That would about 17mm.
Old 04-17-15, 06:34 AM
E
Thanks Pulpo but pipe size, like TV diagonals is one of those places where, even in metric using countries, imperial measurements still hold on.
