Hi all!
I ordered a 9v charger for my Pro 94 but the charger that was sent to me doesn't fit the small jack on the radio! The voltage & polarity are correct but the plug (?) on the end is too big like the normal or common size for those kind of chargers! Did they make the radios with different size jacks & I just ended up with the wrong one?
Thanx, MrPop
You can power the PRO-94 using a 9V, 300 mA AC adapter and a size H Adaptaplug
The size H adapter is 1.3mm. It is the small coaxial plug.
Cautions:
You must use a Class 2 power source that supplies 9V DC and delivers at least 300 mA.
Its center tip must be set to negative and its plug must fit the PRO-94's POWER jack.
Many chargers come with a set of adapters that allow the adapter to work on most anything. Just one example
[img]https://cimg3.ibsrv.net/gimg/www.doityourselft.com-vbulletin/2000x1504/6e86a2d4_c3c9_4f7b_9a77_89422995e568_2e1ee4819a245e5b6939c054ffc4dc017a0541ba.jpeg[/img]
[img]https://cimg7.ibsrv.net/gimg/www.doityourselft.com-vbulletin/2000x1504/6c44d7fa_8771_480e_9273_a53a3cd82f6d_08669e55ae7b5f8261b084218c280080bb0dee8b.jpeg[/img]
[img]https://cimg0.ibsrv.net/gimg/www.doityourselft.com-vbulletin/2000x1504/64386757_505c_4972_9203_65908a435745_263fffc4755ac815f1f14a962481783631d99f14.jpeg[/img]
When I moved into this house, which was built in 1994, I noticed that the telephone network interface box had been cut, as shown in the photos. It is a real eye sore, and I am wondering what I should do about it. Does anyone have any suggestions? Thanks!
I’m looking to install a digital surveillance system with a network digital video recorder (NDVR) and powered over Ethernet (POE) cameras. These are simple as you just run a standard Ethernet cable from NDVR to camera. My question is related to camera resolution. There are many 8K cameras available for a reasonable price but my concern is that if I use a bunch of them that remote viewing will be sluggish due to the bandwidth needed to retrieve those images. Most viewing will be from home but they all come with an app that will allow viewing over internet with a smart phone. Just wondering if anyone else has tried 8K cameras and had problems with remote viewing. The sales rep did advise it would slow down refresh rate but looking for end user input. Thanks!
TexasFire
