4 wire vs 2 wire phone cord/line
Old 11-21-22, 10:13 AM
B
Received 2 Upvotes on 2 Posts
I have an old Panasonic Digital Super Hybrid System in my house. It requires special phones to work on the system. It also needs a phone line/cord from each phone to each jack that is different than your standard phone line/cord - On inspecting the line it looks like it has 4 wires at each connector rather than only 2 wires which I see in typical phone cords. Is there a name or type of line this is called rather than 4 wire vs 2 wire, etc?
Old 11-21-22, 10:44 AM
P
Received 2,121 Upvotes on 1,899 Posts
Most phone cables have four conductors so if you just look for phone wire you should find what you need.
Old 11-21-22, 12:00 PM
Z
Received 416 Upvotes on 369 Posts
The modular (push-in with the locking piece of plastic) are called:
RJ11 (2-wire)
RJ14 (4-wire)
RJ25 (6-wire)
They all fit in the same size jack and are interchangeable, other than the number of wires.
Though they are often all called 'RJ11' cords, so you need to look closely at how many wires the cable has that you're using. Most RJ11 cords you buy actually have 4 wires. But obviously not all.
Old 11-21-22, 12:16 PM
B
Thank you got it. Not sure why most of my phone cords lying around are of the two wire variety
Old 11-21-22, 07:30 PM
Received 3,898 Upvotes on 3,494 Posts
The two wire cords are inexpensive import cords designed for the bare minimum needed.
Old 11-23-22, 08:23 AM
T
Received 190 Upvotes on 166 Posts
Telephone cords have no RJ designation, but, like the connectors installed on them, are designated by the number of Positions on the body of the connector and the number of Contacts in the connector/Conductors in the cable:
NumericAlphaNumericAlpha
For example, a 6P2C cord is a 6-position connector on a 2-conductor cable, a 6P4C cord is a 6-position connector on a 4-conductor cable and a 6P6C cord is a 6-position connector on a 6-conductor cable. A 6P2C connector may only have 2 of 6 contacts installed in the connector body and a 6P4C connector may only have 4 contacts installed.
Why install all 6 contacts and use 6-wire cords? Cost! The contacts are gold plated and copper is not cheap. So why install 2 or 4 extra contacts that are not used probably 95% of the time. Same goes for the number of conductors in a cord and even the number of contacts in a jack (see attached PDF for example).
I suspect most cords were 6P4C initially because there were still a lot of the original Princess phones that used 6 volts AC from a premise transformer to power the lights in the set. Note: If you run across one of these transformers (usually marked Bell System) manufactured by Ault, trash it; they caused a number of fires.
PDF: Site won't upload my PDF, so here is a picture.
