Want to back up Hard Drive
I've looked at Drive Image but they say I need a minimum 8X CD drive - I only have 4X.
Norton Ghost seems to have bad reviews.
Is there any reason why I can't just "copy" the folders from the HD and "paste" them to the CD drive. This seems to be better than buying software to do the same thing.
easy - use explore to drag and drop
You don't need special software to do a backup.
You don't need to back up everything all the time.
Go to explore (not explorer) and drag and drop to your burner.
BobF is right, there is no need to buy a special program to backup your hard drive. But, backing up using 3rd party software such as PowerQuest's Drive Image makes things a lot easier. I agree with BobF though. If you use Drive Image it, makes you backup your entire harddrive. If YOU back it up you can choose any files you want.
There is really no need to backup the entire drive unless your computer is mission critical and you must have it up and running in the least amount of time. I would only backup the documents and files you downloaded/made/received. Windows can be reloaded fairly quickly, drivers are available online or supplied on CDs, and programs come with their own CD. 5 years ago it used to make sense (1G drives), but right now it's pointless. It's quicker to reinstall most programs then to back them up.
I agree that backing up the whole drive is somewhat unneccesary, but I have wanted to copy my original HD to a new larger, faster HD. I used the DOS command xcopy32 to copy all the files from one drive to the other. Want much faster than messing with Ghost(which is rather difficult for a novice). I keep the old copy and update it occassionally. Would make restoring much faster if I have any HD crashes.
Most new hard drives (WD, Maxtor) come with a utility to transfer the contents of the old drive to the new drive. I've used the WD one several times and it works pretty well. But while doing a piece by piece install is slower, I prefer it that way, it tends to cause fewer problems. But Ghosting works pretty well in some cases. However, a weekly backup can't be missed. You can easily reinstall windows, but it's not fun retyping a 20 pg term paper.
