Acer Laptop battery problem
My acer Laptop extensa 390 model will not run on it's battery. It shows 100% charged but it gets to about 92% and computer goes into low power shut down mode. I've tried this battery on an exact same computer and it works just fine. It appears that there is a problem with a circuit regulating the amount of battery power. Is this difficult to fix? Is it expensive? Can I do it myself? The laptop runs fine on AC power.
Yea that sounds like a bad battery. Is there a Batteries Plus in your area? Do a search for them on Google etc they are everywhere. They can rebuild the battery cheaper than new but they can also get a new one reasonable too. Try to go back with Ni-MH batteries. Nickle Metal’s seem to last longer and provide more stable power than NiCD.
Received 0 Votes
When you say another computer works fine on this battery, how long does it work fine? If it works for the right time, then you probabably have a bad computer, not battery. A bad battery would cause the same symptoms on any computer.
Wallyk,
Try turning off the power managment setting and see if that works. It could be a bad power monitor chip. If that is the case, I would suggest you send it in unless you are EXTREMLY knowledgable on hardware. It is a major undertaking. Hope this helps.
