Dns Settings
Old 03-05-03, 03:56 PM
Dns Settings
Problem: I changed my DNS settings to my ISP specs but they won't stay. They keep going back to the original settings. After I change them, I ok my way out, then go back to check them, and they have gone back to the original. Whats Wrong!! Thanks
Old 03-05-03, 05:17 PM
What OS are you using? What kind of hardware do you have? What kind of connection do you have?
Old 03-05-03, 06:20 PM
Windows 98,< Modem, Conexant SOFTK56 DATA FAX PCI V.90><HARD DRIVE, 15.OGB ULTRA DMA><HP COMPUTOR>THANK YOU FOR YOUR RESPONSE
Old 03-05-03, 07:06 PM
You shouldn't have to change your DNS settings on a dial-up, as far as I know. What ISP are you using? A local ISP? Big name ISP? etc. It's been a while since I've been on dial-up, so I don't recall. But usually DNS settings are for DSL and Cable internet users.
Why are you changing the DNS settings? Is the ISP telling you to?
Old 03-06-03, 02:48 AM
I am using a local ISP. Some time ago, they did a "hardware" change to their server. When we first started using them, there were a different set of settings. I guess up til now, those setting were not an issue. I recieved a message from them yesterday, saying I needed to check and change those settings because on 3/24/03, they would be shut off. Thats when I found the problem. My ISP is <HENDERSON ON LINE>
